Why do you half the power
psycho72
I keep reading people posting get this get that it'll be 1000watts (500 each speak) or 1500 (750 each speak). Lets say for arguments sake I had X amp that was 2ohm stable rated at 200x2 @4 Ohms, that would mean if I bridged it that would be in the neighborhood of 400x1@4Ohms and if I were to show it a 2Ohm load that would put power near 800wx1@2Ohms, correct?
Then I have two Y subs, 15 inch dvc's. I then wire the subs together for a 4 Ohm load and connect my amp. As the amp is bridged it sees half of whatever load is attached. A 4Ohm load becomes 2Ohm and a 2Ohm load becomes 1 Ohm. Is this correct so far? So then I have it all hooked up and my amp is putting out 800x1@2 Ohms and I connect my speaks which are showing a 4 Ohm load which the bridged amp only sees half of so as far as the amps is concerned it is putting out 800x1@2Ohms.
Now should'nt the speaks be getting 800w each as it is the same load same circuit and the amp is dumping 800 watts out. Energy does'nt give a F about how many speaks it only cares about how easy it is to flow through the circuit and complete it, right? Please set me straight on this.
No.
http://www.bcae1.com/ohmslaw.htm
Ohm's Law.
To make it easy: A power supply (amp) can only put out so much power. In your example (800X1@2), each 4ohm motor would receive 400 watts.
I tried reading that link but I can't do it right now, I will have to take some time because my little brain can't get it right now. But your comment mentions each 4Ohm speaker I am saying wire each speaker to 2Ohms (parallel) and then the two 2Ohms in series. I will reread it a few times but this crap is confusing //content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif
if you have One speaker that is Dual 4ohm, you can ONLY wire it to 2 ohm or 8 ohm.
From there you can wire a pair upto (series) 4 or 16 ohm. Or wire down to (parrellel) 1 or 4 ohm.
if you have One speaker that is Dual 4ohm, you can ONLY wire it to 1 ohm or 8 ohm.From there you can wire a pair upto (series) 2 or 16 ohm. Or wire down to (parrellel) 1 or 4 ohm.
LOL....Ok, you lost me? ONE dual 4ohm/coil sub can be wired to 2ohm or 8ohm. Two pairs can be wired to 1ohm, 4ohm or 16ohm.
//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
thats what I said. but not quite. You see, I said... then you said.... and one DVC, and two pairs... and now I've gone all cross eyed.
What?
And then...
From there you can wire a pair of Dual 4ohm speakers upto (series) 4 or 16 ohm. Or wire down to (parrellel) 1 or 4 ohm.
-or-
And then....
Two pairs (?) can be wired to 1ohm, 4ohm or 16ohm.
*edit* I got it now. Typo, derrrr.
And then...
-or-
And then....
LOL....um, yeah....... I think:
Should have read two DVC 4ohm/coil subs can be wired to 1ohm, 4ohm or 16ohm.
Bah, screw car audio; I just want to dance
And that! folks, is the moral of the story.
yeah but if you have two 2ohm dvcs? Then I could wire them into 2Ohms for the pair right? And my amp well that is a early Hifonics when they were the shyt and if takes 2Ohm mono just fine (well at least it used to as it has been a while since it was wired like so, actually when kicker was stillwater designs and they were worth something).
psycho72
psycho72
Los Angeles
squeak9798
