Why disconnect the negative
disconnect which ever one you like, both will break the circuit. But then the postitive terminal is still hot if it comes into contact with metal, thus still shorting out the battery. Disconnect the ground you make the whole battery useless so the current wont go through.
From a safety standpoint there is a big difference which wire you remove first. If you take your wrench to the positive terminal and accidentally touch it to a metal part you can accidentally cause a massive short circuit complete with sparks, molten metal flying through the air, and possibly an exploding battery. (assuming a negative ground vehicle)
If you had removed the ground wire first there would be no short circuit if you accidentally touch your wrench to a metal part of the vehicle.
As psycho said, the real reason for disconnecting the negative and not the positive is because if you are disconnecting the positive wire and accidentally ground your wrench or ratchet, you will cause an instant short with a massive conductor. Needless to say welding will occur. This is not recommended.
azeroth123
azeroth123
Lindenhurst, IL/Bloomington, IL
Lakota
NorthFramingham
    Jun 30, 2026
