Why Chamber A Dual Sub Sealed Enclosure?
Would you get more dbs with a box not having a partition?
No. I already said there would be no difference in sound. A difference in output would be a difference in sound.
Casue 2 subs playing on their own channels need to be seperated if not they cancell out. 2 different frequencys in one chamber not good
The only way the subs would cancel out is if they played the same frequency out of phase from one another. If that is the case, the partition in the box is going to make NO difference at all.
The reason you would want separate chambers would be if you had stereo bass (which is very, very, rare) and even then, the difference wouldn't be very noticeable. One driver playing the signal the other is not playing would just fight slightly against the other driver and there would be some distortion.
And I hope you know that your speakers and subs play far more than 1 frequency at a time. Multiple frequencies in a single enclosure is not going to harm or change anything. Now, two different signals being played by two different drivers is a different issue but in the realm of bass, it's not really going to happen.
Psycareyo
Psycareyo
NY
armcclure
