but those tear, strech etc, why not a stopper of some sortThere is a few high power subs that do use fuses, Kenwoods flagship spl woofer has fuses, I don't really see the purpose though. You could try a cheap inline fuse holder on the positive speaker lead I don't know what sizes you would need though.The spider and surround is whats used to limit excursion, somtime they put dual spiders for added strength.
adding spiders doesnt necessarily make it stronger...changing the suspension (more/less, soft/stiff spider along with a beefier surround) changes the overall q of the driver...you change anything and its a different sub....take for instance the re hc, I could name 5 companies off the top of my head that use/used that motor...but all were "different" do to the susp...There is a few high power subs that do use fuses, Kenwoods flagship spl woofer has fuses, I don't really see the purpose though.The spider and surround is whats used to limit excursion, somtime they put dual spiders for added strength.
Ohm's Law would tell you...depends on what power level and impedance your amp was running at. Expect something in the 10-20 amp range though.You could try a cheap inline fuse holder on the positive speaker lead I don't know what sizes you would need though.
Cheers!have a cold beer for ya
why couldnt you slap on a 10 amp fuse and turn the gain up just before poppin the fusehttp://www.google.com/search?hl=en&q=ohm%27s+law
I get 8 amps.
But - all of this doesn't tell you how to set your amp's gain correctly, so you might not know how much power you're actually putting out //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Use Ohm's Law for that, too.
