Why aren't more of you guys using horns?
what do you guys think about this horn driver?http://www.usspeaker.com/bms%204540-1.htm
i wish there was a way to fit it into the ID horn bodies
are there any other 1in horns that you guys think would get loud, sound good, and have good frequency extension?
does anyone else make a horn body that is sorta like the ID in a 2in?
I'm pretty sure you already asked this question, in this very thread. I'm also pretty sure the answer hasn't changed since then.
i emailed ID and the set of horn bodies is 180, the id horn bodies help both imaging and mounting correct so even if i got another horn body that would fit it still wouldnt work as well in a car situation as the id's right?
Of course ID is going to tell you that, in hopes that you'll believe it and buy them. The thing is though, the IDs are the easiest to purchase, the few other horn bodies that are out there, IIRC they aren't produced any more which means searching high and low for someone selling a set.
are the IIRC bodies made for car audio? couldnt i just get another horn body that would fit the driver and fit in my car or will it hurt imaging and what not?
Typo, it should have been "IIRC, they"
You can do whatever you want. Try it out, if you aren't happy, then move on to something else.
ID horn bodies are about the only ones still made. the other companies don't make them any more or they cost ALOT of money. mounting regular horn bodies in your car won't help with your staging or imaging. especially if mounted under the dash as ID horns are.
amartin_72
Banned
amartin_72
Madison , WI
Horsemanwill
