Sold Who needs 1kw @ 4ohms?
RAM_Designs
SketchUp Master
If you do, then I have the amp for you. I have a Kicker KX800.2 for sale. Used, currently being used in my truck, and works great...tons of power in this thing. There is some good wear on the screw heads and terminal connections, and some scratches on the amp...it's nearly 10 years old so it's had it's share of installs, but this thing puts out some serious power; great for a power hungry component set, midbasses, or a good sized 4ohm sub setup.
$220 shipped via paypal gift
200x2@4ohms
400x2@2ohms
800x2@4ohms
3x40amp fuses
Birth sheet was right around 1kw bridged
and the guts via ampguts
Kicker KX800.2 inside - Amp Guts
How good would this pair with a Kicker L7 15 thats 4 ohm?
I believe the L7's only come in Dual 4ohm or Dual 2ohm configurations. So if yours is a D4, then this won't work optimally with it. Now if yours is a D2, then you can wire it to 4ohms and get full power from the amp.
RAM_Designs
SketchUp Master
RAM_Designs
Rockwall, TX
RAM_Designs
