White fuzz noise WTF???
thedukey42
So I have changed head units from 880prs to cd7000, changed mids amp, changed sub amp. Nothing will get rid of this constant noise.
I checked all grounds, from battery to alt grounds. I am pissed so I feel like i'm rushing through this explanation.
I have a run of 1/0 for each + and - from my front stock camry battery to my hc2400 in the trunk. I have that wire on the left side of the car. I run my rca's on the right side of the car, never do they cross.
Speaker wire is ran both sides of the car.
I thought it was my cd7000 ground, so I took a direct route by running a wire outside of the car to the negative on the battery, still had the fuzz.
No matter if my car is on or off, the noise is constant, this noise does not change with the volume of the head unit, at any time if i pause it or turn the volume to 0, the noise is at the exact same level.
I'm so **** tired of this and looking for any help.
thanks
The RCA wires crossing the main power wire is not a huge concern. I would worry more about the RCAs crossing the computer for the car. Try doing what you did with the ground wire with the RCAs. Take them outside of the car and run them to the amp. That will let you see if it the signal cables picking up something.
thanks
Haunted. Sell your car. Buy another one.
thedukey42
thedukey42
Cleveland, Ohio
bonesninja
