OP
bird_dog0347
- Thread Starter
- #16
I tried ALL of the things that were suggested... Including re-grounding the HU to the frame. That made absolutely NO difference.you have a ground loop between your headunit and amp, disconnect the ground wire from the from headunit that goes into the harness, put a ring terminal on the end and attach it directly to a bolt behind the dash (you may have to add a little extra wire to the ground wire to do this.
I bought filters the other day and tried those, but it made no difference. I returned them and traded them for a line out converter. I don't know what you are trying to say, but the LOC I bought taps into the right and left channel of the speaker outputs from the HU and converts it to RCA outputs.What do you mean traded RCA filters for a line out converter? L-O-C only converts high level to low level signal..
