blobb454
I purchased a DC 12" level 4 from mylow and also a AQ HDC3 18" from wes669. I am having double07 build me a box for either one. Both enclosures are slightly expensive but you get what you pay for. So what I need to hear from you guys with experience with these brand of subs is, which would you run? Im leaning all over the HDC3 18. I have JUST enough space to build a box for the 18" for proper specs needed. The amp I have is an old school Cadence Z1200. Ill bridge the sub (which ever) down to 1 ohm (DC sub) which should put power to about 1200 rms. The AQ, if I remember resistance right, will be bridged down to 2 ohm so 800 rms. What the **** would you run? I have an issue playing //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif with different subs. I have a couple already in boxes and switch them around from time to time.
