bdonkersgoed
Hey Guys,
What would you recommend as an excellent SQL sub that is either 12" or 10" for a small sealed enclosure (0.65 cu. ft.). The enclosure cannot change because I am doing a stealth box install in my '99 VW Passat where the box will fill in a little unused cubby hole in the trunk.
This sub will be powered by my Orion HCCA 225G4 cheater amp with the following power output:
2 x 25 @ 4 Ohm
2 x 50 @ 2 Ohm
2 x 100 @ 1 Ohm
2 x 200 @ .5 Ohm
1 x 100 @ 4 Ohm
1 x 200 @ 2 Ohm
1 x 400 @ 1 Ohm
So far I am considering the Image Dynamics IDQ12 D2 v.2 hooked up in parallel to the Orion HCCA. This would give me a 1-ohm load for 400 watts of power (the IDQ is 350W RMS). Also, the IDQ only requires a 0.55 to 1.00 cu. ft. sealed enclosure which would work nice for my application.
I have never heard an IDQ before. I'm not even sure if they are in Canada (but I can order through http://www.cardomain.com). Are these good SQL subs? Can they still play decently loud when you want them to? Here is the cardomain listing:
http://www.cardomain.com/item/IDSIDQ12D2V2
What other subs should I be considering? I would be willing to go with a 10" as well so that it will fit the box.
Thanks!
Bryan
2 x 25 @ 4 Ohm
2 x 50 @ 2 Ohm
2 x 100 @ 1 Ohm
2 x 200 @ .5 Ohm
1 x 100 @ 4 Ohm
1 x 200 @ 2 Ohm
1 x 400 @ 1 Ohm
Thanks!
Bryan
