Which One
Kicker Car Audio 07DCVR124 COMP VR Dual 12" Car Subwoofer Enclosure 1600 Watts Max
Kicker Car Audio 07DC124 Dual 12" Loaded Vented Comp C12 Subwoofer Box 600 Watts
So you are asking us to choose between the comps vs. the comp vrs?
Are you set on getting one in a prefab box or are you willing to try to build one?
We're all beating on you man. You need to do some research about watts, learn ohms law, etc. You can't just buy 2 subs. You definitely can't buy an amp just based on wattage. And you definitely cannot expect anyone to give you an educated response without knowing more about the equipment you're talking about.
Post links to the subs you are looking at. Telling us peak wattage is useless. We need to know the rms wattage for each sub and their voice coil configurations. This will let us know what your final load will be to determine what amp you will need. 600 watts @ 2 ohms is way different than 600 watts @ 4 ohms.
He did.
Kicker Comps vs VRs.
Prefab box. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Yea i dont know much so i guess which one would be better for a jeep and sound quality.
It is coming in a box one is vented and i think ones not i dont know if tht matters
•07DC124
•07DCVR124
i dont care what you say i just want to freakin know what i need im not gunna even get on this site when i get my **** answer you my freind are a complete ******* you feed on others peoples mistakes cause your a dush. i dont anythin you right but i know about other things i dont want to research just get it and use it it my car.
Then if you don't want to be educated, it doesn't matter wtf you buy.
Go kill yourself.
Enjoy your deebeeeeeeez ***.
That post was to help you.
**Brand New Kicker DC124 Dual 12" Loaded Vented Comp C12 Subwoofer Box **Dual 12" Vented Enclosure with Kicker Comp Subwoofers **4 Ohm Final Impedance **Peak Power Handling: 600 watts **RMS Power Handling: 300 watts **Oversized ports with flared ends for efficient air flow and no noise **3/4" MDF Construction **Heavy duty black carpet covering **Embroidered Kicker logo **Dimensions: 32-3/8" W x 16" H x 17-3/8" D (Bottom) x 13-15/16" D (Top)
and
**·Brand New Kicker DCVR124 Dual 12" **·CompVR Loaded Vented Enclosure **·Dual 12" Vented Enclosure with CompVR Subwoofers **·4 Ohm Final Impedance **·Peak Power Handling: 1600 watts **·RMS Power Handling: 800 watts **·Oversized ports with flared ends for efficient air flow and no noise **·3/4" MDF Construction **·Heavy duty black carpet covering **·Embroidered Kicker logo **·Dimensions: 32-3/8" W x 16" H x 17-3/8" D (Bottom) x 13-15/16" D (Top)
krj725
krj725
Boston
jdawg
