nicksredline
so i am trying to put a system together( consisting of 2 12's) but the max amout of money i am trying to spend is 160 dolors shipped. so the few subs i came up with that i think are alright are listed below( keep inmind that sound quality dont matter to much but the bump for now.) :
SONY XS-L126P5 12" Single 4 Ohms Xplod Series Subwoofer
Peak: 1300 watts
RMS: 380 watts
Impedance: Single 4 Ohms
Sensitivity: 94 dB
Frequency response: 22-1,000 Hz
5-Sided MRC (Mica Reinforced Cellular) diaphragm with glass-fiber composite
Stroke stabilizer rubber surround
VOLFENHAG ZX-4722
Power Handling (RMS per Speaker) : 350 Watts
Power Handling (MAX per Speaker) : 1200 Watts
Power Handling (Combined) MAX : 2400 Watts
Sensitivity : 86dB
Frequency Response : N/A
Impedance : 4-Ohms
PPI PRECISION POWER PCX122( only reason these subs are on this list is ive never seen a flat coan before and i dont know if its better or what. also has a descent size surround.)
Subwoofer Size : 12"
Design : Dual Voice Coil
Power Handling (RMS) : 300 Watts
Power Handling (MAX) : 600 Watts
Power Handling (Combined) MAX : 1200 Watts
Sensitivity : 82dB
Impedance : 2 Ohms
Mounting Depth : 6.18"(157mm)
Approximate Weight : 30.6 LBS
14mm Xmax
Q POWER Mamba
MAX POWER: 1200 WATTS (2400 Watt Pair)
RMS POWER: 500 WATTS ( 1000 Watt Pair)
OVERALL WIDTH: 12.2"
MOUNTING DEPTH: 6.3"
MOUNTING HOLE DIAMETER: 11.1"
FREQUECY RESPONSE: 30-2000Hz
POLYPROPYLENE CONE
BLACK STEEL BASKET
MAGNET: FERRITE DOUBLE STACKED
HEAVY DUTY LEAD WIRES WOVEN INTO SPIDER
NICKEL PLATED PUSH TERMINALS
1 YEAR MANUFACTURER WARRANTY
HIFONICS ZX12S4
12” Single Voice Coil 4 Ohms ZEUS Series Subwoofers
2000 Watt Total Power Handling (1000 Watt Each)
1000 Watt RMS Power Handling: (500 watt Each)
Impedance: 4 ohms Each
Injected Poly Light Rigid Cone
1" NBR Reinforced Rubber Surround
Integrated One Piece Poly Cotton Spider
Nickel Plated Push & Insert Speaker Terminals
Poly Light Dust Cap
Heat Dispersing Ported Back Plate
Ultra Ridged Chrome Stamped Steel Basket
High Strength ABS Motor Cover
Large Air Cooled Magnet Assembly
Sensitivity: 88 dB
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=230345648086&ssPageName=STRK:MEWAX:IT( link to sub box combo)
AUDIOPIPE Dual 12" Ported Woofer Box ( i am closley lookin at this because its already boxed and i beleave its tuned for these subs)
1500 Watts Power (PMPO)
750 Watts power (RMS)
frequency response: 28-150Hz
sensitivity: 102 dB
4 Ohm mono
constructed of high grade MDF
gray automotive grade carpet
12" TS-V12 one piece PP cone woofer
12.9" H x 16.9" D x 27.4" L
1 Year Manufacturer Warranty
Also any other subs (12's=160$ shipped) that would put out some good spl would be very appriciated Thanks Alot Nick
Peak: 1300 watts
RMS: 380 watts
Sensitivity: 94 dB
VOLFENHAG ZX-4722
Sensitivity : 86dB
Impedance : 4-Ohms
Sensitivity : 82dB
Impedance : 2 Ohms
14mm Xmax
Q POWER Mamba
POLYPROPYLENE CONE
BLACK STEEL BASKET
HIFONICS ZX12S4
Poly Light Dust Cap
Sensitivity: 88 dB
sensitivity: 102 dB
4 Ohm mono
