- Thread Starter
- #16
Thanks so much for the reply and sorry I need to be walked through it all.In theory you can run that back battery dead and your starting battery will still be fine. But if you run the back batteries too low i would recommend getting a battery charger to avoid putting too much stress on your starting battery when you close the switch because 14 volt + 8 volt = 11 volt = not good for electrical system.
Connect both batteries with 1/0 wire for best charging. Run 1/0 from Starting battery (to power switch) to Aux battery to Amplifer in that order. all connect the + to + and the - to - .
The big three only needs to be done on the starting battery.
So - to - on battery is better then just grounding to vehicle right ?
Will this power switch even take 0 gauge wire ?
I really like this idea alot.
Wish I was at home so I could paint it n verify .
Both batteries will be up front by the way
I appreciate the help so much !
