Which brand RCAs/D-blocks/etc do you have??
go with lightning audio. That is what i have always had. But a you could jump the input form monitor to monitor. Instead of splitting it at the source. That is if ur headrest monitors have output.
No, they arent headrest monitors and they dont have outputs. Also, have never heard of lighting audio
are u serious U never heard of Lightning Audio????? WOW but you might need a video amp, I mean it would not hurt. But before you buy go to lightning audio website (it is self titled) and look it up. They have splitter.
Get a fused distro. for your power wire, and regular for your ground.
Ok thanks for clearing it up.
I heard ground distroblocks are a waste, but I am thinking on getting one anyway beause it will look cleaner.
Now that I think about it, I have seen lightning audio at walmart, it is yellow and black right? Any reason I should buy their wires and rca's over stinger or street wire or KK??
In a 2 battery setup, the 1/0 goes from the front battery, through the 250 fuse, to the isolator, through another 250 fuse, to the rear battery, to the fused distro? Am I correct in fusing both of those wires?
yeah u are right that is there lowest line. Look into there strike and storm line. go to www.lightningaudio.com it will speakfor itself There higher line distro block are different form the other.
bobo244
bobo244
Miami Florida
95RAM
michigan born
    May 14, 2026
michigan born
    May 14, 2026
