Which Amp ?
Good choice of subs, btw. If you're running 1, then get an amp that works well at 2 ohms or 2 - 4 ohm channels.
It may seem weird, but a good 4 channel amp will give you the specs you're looking for. Bridge it down to 2 channel, and wire to each voice coil.
For example:
Powerbass 4 channel for $150
Crunch Powerzone for $100
Autotek for $100
Sundown 100.4 but a little more costly
Granted the first 3 may not max out the sub, but it'll be close enough to pound and will be crazy cheap.
If you're looking into a long-term amp, get a stronger mono amp
Hifonics 2010
or the Power Acoustik and keep the gain appropriate.
xDATx
xDATx
Los Angeles, CA
tinmanchris217
