which amp is better for the money
  • 4
faygo187
I am trying to power 2 infinity 300 watt rms 1200 watt max 12's single voice coil at 4 ohms and am planning on getting new subs soon 500 watt rms running at 2 ohms
i had an hifonics 1500 watt that got a short in it so i decided to up grade.
which is a better amp
Kenwood 1000W Class D Mono Amplifier
Model: KAC-9102D
Rockford Fosgate Punch 900W Mono
Model: P3001
I was looking at http://www.bestbuy.com so i could have their service plan added on if i have any problems in the future.
honestly, you probably be better off getting your hifonics amp fixed and sticking with it, in my opinion hifonics makes better amps than both brands you mentioned above and that amp will be more than enough to push them two subs, also try shopping on the internet before going to bestbuy, you could probably save a lot of money by doing so
How much would those amps run, with the service plan?
Id suggest an ED 9.1, $350 with a full three year warranty, and a better amp than either of those mentioned above.
More power for headroom/future upgrade too.
There's plenty of monoblocks that are legit rated a fck load more than 1200w...
166
395
  • Locked
702
Amp
511
faygo187
faygo187
Charlotte, NC
n2audio
