Which amp for front 2-way component speakers
MagnusO
UK
Very new to car audio. Looking for an amp to power my front 2-way component speakers:
Focal 30th Anniversary P165 V30
Frequency response (+/-3dB) 55Hz – 25kHz
Sensitivity (2.83V/1m) 92dB
Nom. power 80W
Max. power 160W
Nom. impedance 4 Ohms
Head unit is Pioneer DEH-80PRS and the sub Pioneer TS-WX77A 200w (built in amp)
The Amp will need high pass filters to removes the low frequencies, as it will not be powering the sub.
Thanks, Magnus from UK
New or used, not bothered. Budget would be around £200 ($350). Not looking to shake the neighbors so would prefer SQ...(or a bit of both!).
Eying up these now instead of the Focals!
JBL MS62C
160W RMS power handling (320W peak)
Frequency response: 60-20kHz
Impendence: 4-ohms
Sensitivity: 89 dB/Spl
10
565
The end result is, not the intention. I think OP got what I was saying. The Brits generally aren't as sensitive. A 500w sub amp does not...
17
Sounds like your front stage is overpowering your sub stage/ Weak sub stage. Is this a 4dr. Sedan or a Hatchback WRX? Where do you have the sub...
22
May be a weak link. Hifonics has been pretty dubious for going on 30 years now.
142
MagnusO
MagnusO
UK
Kingstroker
    May 18, 2024
    May 18, 2024
