Which Amp for a 4ohm DVC
mred33
Need to know what channel amp i need for a 4ohm DVC sub? Im pretty sure its a 2 channel amp but also would like to know if a mono would work. And then last, what is a good brand that isnt expensive?
Im all new to this again, i played around a lot w it 8yrs ago...
for a single sub you can run a mono amp......even if you have a pair of subs you could run a mono amp.
the dvc 4ohm can be parallel wired to 2ohm. find an amp that does whatever power you are looking for @ 2ohm.
Need to know what channel amp i need for a 4ohm DVC sub? Im pretty sure its a 2 channel amp but also would like to know if a mono would work. And then last, what is a good brand that isnt expensive?Im all new to this again, i played around a lot w it 8yrs ago...
How many watts is the sub? Or which sub is it?
mred33
mred33
North GA Mtns
ThumpinTitan
