Where to get somme good midbass for active setup
twisztdauthorit
-db-
Ok so i need to find some midbass/midrange speakers in my price range and cant find many on partsexpresspower range is 100(@4 ohm)-200(&2 ohm) per channel Im thinking bout having 2 sets of midbass/midrange per door and would try to keep it under 100$ for all 4. Im flexible on the setup( and price) though so voice your opinion please.try to keep size under 6.5I would search but im on a shitty school comp through a proxy and it takes for ever to load pages.
Are you running 3 way active? If not, then I would suggest against running two midbass/midranges up to the tweeter highpass as you will need a lot of processing to fix combing issues and imaging...
What you CAN do is run one of the midranges up to the tweeter highpass, then run the second in parallel, but with a passive lowpass around 150hz...or if you have the channels both run active...
Or, run eights //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
sorry, need to clear things up. I am looking for midrange not midbass.
the mach 5's play good up until around 4-5k. Highpass around 60up. Some people even run them full range without a lowpass, using them full range and letting the speaker naturraly roll off. Playing that high you should be able to use pretty much any tweeter.
I picked up a set of these from hessdawg last week:
http://www.caraudio.com/forum/showthread.php?t=264323
and so far I'm very satisfied with the performance for $90 SHIPPED.
I'm using them in a 2 way active setup crossed at 80Hz, 12db/oct, and 3.2kHz, 12db/oct, and they sound great. Very nice midrange detail, with a nice midbass punch.
He shipped fast, and communicated quickly, too. I'd highly recommend that deal.
^ those are six inches deep though. good luck with that.
im not worried bout depth.. there going in a custom FGpannel and will have plenty of space.
i would like to grab those ID but i cant afford both sets now and would not like to have to pay full price when i can afford the 2nd set=/ sorry im a cheap *** looking out for good deals //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
I also see some CDT midranges going for under 100$ a set.
twisztdauthorit
-db-
twisztdauthorit
Bakersfield, CA
redcalimp5
