where to buy egg carton foam?
a lot of people use the egg crate bed topper pads from walmart. if you use that though, you will definitely need to treat it with a mold killer and maybe scotch guard because water will get to it in your doors and it will mold/mildew
if you are using as damping, you don't need egg carton foam... only reason they use that in studios is to give a ratio of direct to reflected sound... as damping, you want to eliminate reflections where you put it as much as possible.
The regular 1" thick open cell foam rubber is sold from a roll... used to get it from the rag shop around here (fabric/craft store).
so it doesn't really have any advantages over ensolite, in say, the application of putting behind your midbass drivers?
i ordered edead vs1e and the guy on the phone said not to use egg carton foam because it will hold water and cause problems, he threw a 1 sq ft section of thier v4 in with my order and said to use that behind the speakers in the doors. he said to use a 6x6 piece and checkerboard another layer on top of that.
- Basically, different materials are better for different jobs... the open cell foam and egg carton foam is mostly for midrange... and some road noise... something heavier, with more mass is needed for sheet metal and doors, for midbass/bass, is better for road noise... basically you need to add weight to panels to keep them from rattling/vibrating. Sometimes you want both kinds of materials, other places, just one type will do.
Might want to be careful about putting open-cell foam in doors... they are designed to leak, so the stuff might hold water... might even get moldy and smell up the car.
yea thats what the guy at ED warned me about so i took his advise and got the V4 from ED.
right, i knew about the panels, i have about 10 yards of ensolite, and 150 sq ft of raammat in my explorer, but for behind the speakers i went with 10x10 squares of open cell foam. have yet to check them for mildew after about 2 months but i haven't noticed any odors.
tcguy85
tcguy85
Hyde Park, NY
Lil Poot
