Where the heck would I put the cap if I were to........
hogger
Okay I am definately eventually going to put in a four channel amp to power my mids and highs, and I am oging to get a capacitor too, but I was curiouis, should I wire the capacitor in to where it only feed to the sub amp, or to the four channel amp as well? Just curious, thanks guys
well now if i understand correctly your going to need a fuse distribution block with 1 power wire from the bat. back to it, then 2 fuses for the amps then that, down to 2 power wire's for your amps, same as for your ground wire stuff. now wouldn't you run the power from the battery back to the cap, and ground straight to the cap, then those wires to the distribution block's and then that to the amps?? that's how all the setups with multi amps that i've seen have it run.
adam
I usually just plug the cap into a distribution block. I use Stinger blocks they have 3 4awg inputs and 2 8awg outputs. main power goes into the block, power wire for the cap goes into the block and if I have more than 2 amps I run a second dist block off of the last 4awg input.
hogger
hogger
Murray, KY
blackgeltabs
