tuckintaco93
where does everyone hook there volt meter to ...amp power or to the battery ...should be same power at both places but not sure
Are you sure that is true cause your current build log has your voltmeter tied into your headunit???I always just measured the amp, don't really care what the voltage is up front lol
Nope - he has the same elcheapo 2 wire ebay via Hong Kong unit that I have.^^ He prob has it like me I have my stinger meter spliced into my HU's ground and remote wire and have my 12v source connected to my amps terminal
I am confused - you do not care what the voltage is up front but you wire your volt meter to measure the up front voltage.I always just measured the amp, don't really care what the voltage is up front lol
I was going to run a wire all the way up front/back to get the voltage but what I did was just tap into the headunit's turn on wire (the red wire). It is activated by a relay when only the car is on and has the same voltage as whatever the alt is charging at, it's not some weak 2v signal.
