usually that's only if you stick it in the small slotstick a paperclip in an outlet and you'll also see that spark //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
in my mind (assuming you closed the box faster than the speed of light) i would think you would be correct.i guess this would be an appropriate topic to ask a question i've always wondered as well.....
ok so lets say i have a cube made out of 6 mirrors facing the inside of the box. If I "open" the cube by sliding a mirror a little bit, and shine a light inside, then hurry up and close the cube while the light is still be directed into the cube, is the light trapped inside? If I go into a pitch black room and shatter the cube, will i see a flash of light real quick? or does the energy of the light disappear too quickly?
ok then scenario 2...//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif Im pretty sure you couldnt close that cube fast enough...light is teh quickness.
LASERs use 98-99% mirror on one end, 100% on the other.ok then scenario 2...
all sides of the box are two way mirrors like in police stations. where i can just keep the box closed but still shine the light in, and once it's in it can't get out? i would assume those aren't 100% efficient though in the reflecting?
so it wouldn't work then?LASERs use 98-99% mirror on one end, 100% on the other.
lol.LASERs generate the light between the mirrors.
Light is analogous to sound. The same way that you can increase the SPL by bouncing a sound wave back and forth between 2 reflective surfaces is similar to how you intensify light. You bounce the light between mirrors which increases the overall energy of the beam. That is generally how it works.lol.
i'm sorry. care to explain? so you are saying it would or would not work? i'm not understanding which side you're trying to explain
Ill Mitch can board faster then the speed of light //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif Im pretty sure you couldnt close that cube fast enough...light is teh quickness.
a LASER is a gas-charged apparatus with electrical leads inside and built with mirrors on the ends. the gas gets charged between the mirrors, making the single frequency light that is ...well:lol.
