When will doubling the power really add 3dB?
ghart999
I have two RLp 12's in a 2.2cf box ported to 34Hz. I know the box is too small right. I had the design done by Team Toxic Bass and this is what they came up with based on my trunk size and listening prefs. Well it sounds fantastic to me.
Anyway - I have 500w per sub and am hitting 143 dB on some old school bass music (Techmaster, DJ Magic Mike, etc.) Would doubling the power likely add another 3 dB as it would in theory? Or might my box size, car, etc reduce this ability? The RLp's are rated at 500-1000W. So I am on the lower end. I would certainly spend the money for another 2.5 - 3 dB gain. But not for 2 dB or less. What are your thoughts.
Thanks all.
Doubling the power would only begin to increase the SPL level by 3dB in a perfectly controlled lab-type environment.
In your car the changes will likely be considerably less dramatic...
That's what I figured. So probably not worth the extra $$$ for 1000 extra watts.
doubling the power will not always give an extra 3 db some it may add 2db+ you can usually add more power to gain db's till you have reached your power compression of the sub. If you want it louder get more watts //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
egg
Wow, doubling power only gives you a little DB boost? I didnt know that. Would you "feel" the bass alot more with a 3 DB increase? I have a sub amped at about 480 with a 2 channel amp and I was contemplating getting a mono sub that put out 600 rms. I take it, it's probably not really worth the money then?
3db is twice as loud
a 2-3db boost you should feel it more and it will be louder example turn your head unit to volume 10 than turn it up to volume 20, can you feel it more is it louder?? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Ok I got a question for you guys.
Would there be a huge volume difference in 1 12" sub getting 800 watts over 2 12" subs getting 400 a piece? And I am comparing the same sub, just 1 vs. 2
ghart999
ghart999
Denver, CO
sku
