So in terms of actually listening to your music does a cap do anything at all, ever?
Here's my checklist of *extra* capacitors added to an existing good amplifier
design. The audible effects are;
Car Audio Ampliifers
When you add *extra* 'stiffening' capacitors to either the input and/or output side of the
SMPS found in car amps, it would be very hard to notice an audible difference. If you were
to perform a proper blind test, you would fail to identify the amp with extra caps. You can
measure difference with test equipment, but your hearing isn't that precise to identify this.
Non Car Audio Amplifiers [Home or Pro audio amps]
A. Amplifiers with PFC power supply: You won't hear any difference by
adding extra caps because PFC already ensures power is constant even if input
voltage sags.
B. Amplifiers with standard SMPS driving non-subwoofers: You won't hear a difference if you add extra caps to the design
because midranges and tweeters don't present a big load on the amplifier.
C. Amplifiers amps with concentional power supply design driving non-subwoofers: You won't heard a difference if you add extra caps to the design
D. Amplifiers with conventional power supply design driving subwoofers: You might be able to tell a difference if you add extra capacitance to the design.
It really depends on how much there is to being with.
