That is correct.do I put the speaker wires from the amp to the 'in' on the crossover?
Where did you "read" the impedence? On a meter? That is not an accurate measurement. Just use what the manufacturer claims is the nominal impedence. Impedence is frequency dependent and somewhat complicated to understand. So it is expressed as "nominal impedence". A combination of design and complex lab measurments at different frequencies.Because i jus read the impedance on each set and it comes to 2.5ohms so i dont wanna **** my amp up. amp is a sundown 100.2
Ok thanksThat is correct.
Just use the rating on the speaker box or what ever the manufacturer says it is.
Lol! Turn that **** down!!!//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gifTheyre the re xxx comps. Reason I ask is because the amps gain is set to about 3/8 turn, but after listening to it for a while i started to smell somethin so i checked the impedance for each side at the amp and they both read 2.5... i just wanted to double check.
lol ahh it wasnt THAT loud. but nah i disconnected them before i measured.Lol! Turn that **** down!!!//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
If they were still connected to the amp you were measuring the complete circuit, including the amp. Not just the speaker.
No. I'm saying that's perfectly normal, your sundown will have no problems.So what are you sayin? the sundown has trouble when my comps go up to 8-12ohms at higher freqs?
