Whats your all-time favorite car?
I just thought of another one. Koenigsegg CCR
Performance
Acceleration: 0-100 km/h (0–62 mph) 3.2 seconds
Top speed: 395+ km/h (242+ mph)
Standing quartermile: 9 seconds, end speed 235 km/h (146 mph)
Braking distance: 31 m (100–0 km/h)
Lateral g-force: 1.3 g
Fuel consumption: Highway travel: 13 l/100 km
Combined: 17 l/100 km
Body
Two-door, two-seater with removable hardtop stowable under the front boot lid. The body is made of preimpregnated carbonfibre/kevlar and lightweight hard-foam sandwich reinforcements.
Dimensions
Ground clearance: 100 mm (3.9 inch)
Fuel capacity: 80 litres (17.6 gallons)
Luggage compartment: 120 litres (26.4 gallons)
Dry weight: 1180 kg
Areodynamics
Cd. 0.297. Frontal area 1.825 m2. Completely flat underside of chassis. Venturi tunnels at the rear of chassis/body.
Chassis
Semi monocoque made of preimpregnated carbonfibre and with honeycomb reinforcements for added stiffness.
Front and rear suspension: Double wishbones, adjustable VPS custom racing shock absorbers, pushrod operated. Anti-roll bar. Electronically adjustable ride height.
Front brakes: Ventilated discs Ø 362 mm, 32 mm wide. 6 piston light alloy calipers. Power assisted. Koenigsegg Advanced Control system. Rear brakes: Ventilated discs Ø 362 mm, 32 mm wide. 6 piston light alloy calipers. Power assisted. Koenigsegg Advanced Control system.
Wheels
Koenigsegg magnesium alloy wheels with centre locking.
Front: 19” x 9.5”
Rear: 20” x 12.5”
Tyres
Michelin Pilot Sport 2. Unidirectional with asymmetric tread pattern.
Front: 255/35–19” (Y)
Rear: 335/30–20” (Y)
Steering
Rack and pinion power assisted steering. 2.7 turns lock to lock. Turning circle: 11 metres
Engine
Type: V8 cast aluminium, 4 valves per cylinder, double overhead camshafts. Cam cover of carbonfibre.
Displacement: 4.700 cm3.
Compression: 8.6:1
Weight: 215 kg
Lubrication system: Dry sump with unique oil spray piston cooling. Oil cooler.
Oil: SAE 5 W/30 fully synthetic racing.
Oil tank capacity: 12 litres (2.64 gallons)
Induction system: Sequential, multipoint fuel injection. Lysholm twin-screw supercharger with 1.2 bar boost pressure. Intercooler.
Fuel: 98 RON unleaded.
Ignition system: Direct coil on plug. Transistorised.
Power output: 806 bhp at 6.900 rpm.
Maximum torque: 920 Nm (678 ftlb) at 5.700 rpm.
Maximum rpm: 7.600 rpm.
Transmission
Specially developed 6-speed gearbox by Cima. Incorporated internal oil pump and oil cooler. Torque sensitive, limited slip differential.
Clutch: Dual Plate, organic or cintered Ø 215 mm (8.46 inch). Oil-cooled and electronically operated.
Equipment
In standard mode the car is very well equipped with many items that competitors have as options. Many customers, however, want to further equip the car. Therefore we can offer a list of customer options which should fulfil every demand.
Standard equipment
Detachable roof panel
Climate control
Electric rear view mirrors
Leather interior
Central locking
Electrical windows
Alarm with immobilizer
Toolkit
Driver side airbag
Power steering
Hydraulic ride height control
Servo assisted brakes
ABS
Traction control
Stereo with CD-player
Tyre pressure sensors
Car cover
Exhaust system in titanium
Customer options
Parking sensors
GPS navigation and/or tracking system
Telephone system
Rearview camera
Aluminium rear light casings
4-point safety belts
Sequential gearbox
Tailor-made suitcases
Custom colour leather interior
Custom paint colour
Additional noise insulation
Carbonfibre rear twin fin wing
Carbonfiber front splitter
Ø 378 mm brake discs, front
i love my dads S600 Benz. I wouldnt call it my all time favorite car, but its the greatest one i've ever driven. Its a V12. a car magazine (i forgot which one) took one stock, simply took of the speed governer, and got it above 200.
I hope to take out his 911 turbo soon, but i havent had the balls to do it.
1995 Lamborghini Diablo SE30 Jota
Of the 150 Diablo SE's, 12 of these were converted to Jota specifications. Modifications include a redesigned engine cover with twin air scoops to cool the engine. The programmable electronic injection system can tune the engine to produce over 600 hp. The SE30 Jota also has an open exhaust, making it non-street legal. However, several of these cars have been seen driving on the road.
thats truly one badass car
bri487
Banned
bri487
birth canal
denim
