well originally i was going to run 2 9512 with it but i gave one away. Like you see on this post its beating up my single 12. havent had any problems with it as of now. Hey by the way does your mom or someone related to you work for a hospital?how is that mm4000 treating you i loved that thing
Too big of a box and too much power.i believe the box is about 2.75 cu ft before the woofer is in and tuned to about 40 hz. i thought it was the glue burning off because they were never even broken in. the rubbing of the coils is what worries me.
DD recommends a 2.6 cu ft box for the 9512. They also recommend 52 sq in of port to tune to 40 hz. Mine is pretty close to that. How is the box too big and too much power? ill build another one and tune it to 35 hz using reaudios website to help out with all the calculations. Will this matter? a box should be a box regardless of who recommends the box design right? or should I build it using DD box designs?Too big of a box and too much power.
/thread.
If you are going to put 2 times the R.M.S. to a sub you need to shrink the box to compensate for the increased wattage.DD recommends a 2.6 cu ft box for the 9512. They also recommend 52 sq in of port to tune to 40 hz. Mine is pretty close to that. How is the box too big and too much power? ill build another one and tune it to 35 hz using reaudios website to help out with all the calculations. Will this matter? a box should be a box regardless of who recommends the box design right? or should I build it using DD box designs?
You're pushing too much power for that box to be the best choice.DD recommends a 2.6 cu ft box for the 9512. They also recommend 52 sq in of port to tune to 40 hz. Mine is pretty close to that. How is the box too big and too much power? ill build another one and tune it to 35 hz using reaudios website to help out with all the calculations. Will this matter? a box should be a box regardless of who recommends the box design right? or should I build it using DD box designs?
2 woofers would be the better way to go if you can swing it. You get the added benefit of more cone area while not pushing each sub as hard. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifAny other sub out there than can take the abuse? or maybe i can switch to a 2 woofer set up to divide the power to both of them. what about the btl's? i would just love a tc sounds lms ultra 15 but i cant afford that right now!
but if you look at the specs for the 9512 it gives you different numbers. it gives you 2.6. im gonna keep my options open or just make another box or try to find another pair of woofers maybe to droop in there but i cant have anything that will take up too much space as of right now i cant go much bigger than the current box. maybe a pair of 10's would work. Im just not really convinced about the sound of 10's. never had them1.75^ft (2) 8" or (1) 12" 28.0 sq" vent x 21.5" long tunes to 40Hz +/-2.00^ft (2) 8" or (1) 12" 32.0 sq" vent x 21" long tunes to 40Hz +/-
2.25^ft (2-3) 8" or (1) 12" 36.0 sq" vent x 21" long tunes to 40Hz +/-
2.50^ft (3) 8" or (2) 10" or (1) 12" 40.0 sq" vent x 21" long tunes to 40Hz +/-
2.75^ft (3) 8" or (2) 10" or (1) 12" 44.0 sq" vent x 20.5" long tunes to 40Hz +/-
You are on the large side and have to much port. Do the 2.5 or 2.25 box. You could also be clipping some.
