whats the story on Avionixx amps?
cooldudejz
do they put out their rated power, are they over/underrated. are they reliable. i am looking at this amp the avionixx AXA800.4. these are the specs(according to woofersect at 12.5V)
# RMS Power @4ohm
# RMS Power @2ohm
# RMS Power @Bridged 4ohm
# Power Bandwidth (Rated Power -1db) - 15Hz - 30kHz
# Frequncy Response (+0/-3db) - 5Hz - 40kHz
# "A" weighted signal to niose ratio - >-90dba
# Channel Seperation - >60db
# Damping Factor - >100
# Variable Input Level - 15OmV - 6v
# Line Outputs - YES
# Variable Low Pass Crossover Filter - 50Hz - 250Hz 18dB
# Variable Subsonic Filter - 50Hz - 250Hz 18dB
# Double Sided, 2Oz. copper clad, FR4 glass epoxy circuit board.
# Overload Protection - YES
# Short Circuit Protection - YES
# Cross Wire Protection - YES
# DC Off-Set Protection - YES
# Thermal Protection - YES
# Dimensions - Inches - 18 x 9 7/8 x 2 1/4
# Weight - 13 Lb
want to power a set of CDT components.
woofers etc is selling off Avionixx stock. I've owned AXT1200.2's, AXT800.4's, and AXA400.4. ALL have performed very well. They are just out of production.
One note. None of my boxes LIST an AXA 800.4 only AXT800.4
If you wanna power a set of CDT's I've got an AXA in F/S $150 plus shipping.
cooldudejz
cooldudejz
N.H.
djman37
