What's the best SQL sub for my box? SQL Top 3
Injected54
The way the rear bench seat is in my truck it's angled and doesn't leave a lot of room underneath it for subs. I've been looking around for awhile piecing everything together and got a like new down firing box from someone that sold their truck. What's the best or top 3 that would work good in this box and in what order would you rank these subs SQL wise? Here's some specs on the box and the amp I'm running.
What's the top 3 subs that would sound the best with this setup for SQL?
1)
2)
3)
ProBox
OODX210DF '98 and up Dodge Ext Cab Down-Fire Double 10"
L45" x D17 1/2" x H10 3/4"
Hole Size: 9 1/8"
Mounting Depth: 6.25"
Air Space CU FT Vol: .70/side
Dodge Truck Extended Cab
MTX TA81001
Class D Mono Amp Car Audio Amplifier 1500 Watts
RMS Power Output: 750 Watts @ 1 Ohm, 500 Watts @ 2 Ohm
Peak Power Output: 1500 Watts @ 1 Ohm, 1000 Watts @ 2 Ohm
Signal To Noise Ratio: 68 dB
Frequency Response: 20-200 Hz
Bass Boost: +/- 12 dB
Built-In Crossovers: Low Pass
THD @ 4 Ohm RMS Power:
Low Level Input: No
Built in Cooling Fan: Yes
Bass Control Knob: No
Dimensions: 9-5/8 L 20-11/16 W 2-1/2 H
MTX Audio TA81001
Thanks, will a flat magnet sub fit in the box because of the angled mounting? I'm not sure how to find out which one would be needed either. From the factory on the top of the box where the magnet sits they cut a 5" hexagon hole on each side. Then they put a piece of mdf on the top of the box above the hole and sealed it to allow more mounting depth. You can see the extra tapered mdf on the top of the box. Would a flat base magnet work on this or would a tapered bottom magnet style be needed for it like on the FI Q?
I'm open to suggestions if anyone else has any also.
Injected54
Injected54
The Concrete Jungle
Plottin4success
