What's that noise?
One use of white noise is to set up your home theater to be "reference" level.
You bust out a dB meter and play white noise through the whole system. Then you adjust the levels settings such that, at least in theory, your dvds should play back at the "correct" volume level. Correct meaning what the dvd producers say the correct volume level is for watching the movie.
Also, don't you use white noise when tweaking a system with an RTA? Assuming your mic is perfect (or your RTA is calbrated for its error) white noise should look like a flat line when played a perfectly flat system.
I'm not sure. i got no clue..i came across the wikipedia site before but I really wasnt all that sure what it was still used for...but the second post gave me a clearer idea of white noise. thanks.
donpisto
donpisto
Los Angeles, CA
donpisto
