What's happened?
when you are pushing on the cone the "stratching" you are hearing is prolly the coil rubbing from you pushing on the cone. get a dmm and measure to see if there is any resistance. if it is a 4 ohm coil, it should measure around 4 ohms
listen buddy. if you push on the cone, you are going to push it out of alignment unless you do it just right so its going "inwards" perfectly.
if you push on one side, its going to tilt the suspension and rub the coil making that scratching sound. its quite normal.
now ****in stop it lol.
play some music to it, free air it if you have to, and listen carefully. if it sitll makes scratching noises, then your speaker is on the road to destruction.
all your bass are belong to us.
you have no chance to survive.
make your time.
lol ight I'll ****ing stop it... it plays fine in free air, no scratchy sound and when tested with a dmm it read like 3.7 ohms... and it is a 4 ohm speaker.
make your time.
well said req. well said. u deserve a grammys. //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
96civ
96civ
Indianapolis, IN
96civ
