whats difference can I expect between 8, 10 and 12inch sub
ymee
Guys,
Bear with me, new to this stuff. I am in the market for a sub for my xterra SUV to complement my Focal system. Looking for something that will blend with the rest of the system and give a nice kick. Nothing that will make the car shake, rather something I can feel in the small of my back.
So what is the best size sub to get for this purpose? This is a SUV so it has tons of space, do I need a 12" or can I go smaller for my purposes?
Whats the general strategy on choosing a particular size for subwoofers? Oh, and I have a 300W amp for this purpose.
Thanks!
I too have a Xterra and for size consideration/your needs, one 12" would be good enough. However, 300W won't do you any good imho. So you might consider a single 10" or 8" or upgrade the amp.
A 12" is more flexible and easier to achieve your goals. Smaller drivers can still do the job, but bass frequencies require alot of power and surface area to reproduce realistic bass music sounds. Larger drivers achieve that goal more easily.
Since you have the space I would suggest a good 12" in a good box. I prefer a sealed box for SQ.
12" is also the most commons size so you should be able to find more choices and sale prices on 12's.
There are plenty of 12"s that will fill his needs off 300 watts.
Actually I think the opposite. With less power you should have a larger driver. That same 300 watt amp will produce more bass with a larger driver. A 12" or 15" driver will give much better bass than an 10" driver from the same amp. Speaker size is not releated to power handling the way you suggest. The efficeincies work the opposite. You get more SPL per watt from a larger driver than a smaller one.
A single 8" at 300 watts will be a bit weak, but a 15" or 18" at 300 watts may be a bit more "Bang" than he's looking for.
guys,
wow thaks for all the feedback, this forum rocks!
I was looking at the Alpine PDX5 to run my 4 Focal's and the 1 sub. Sounds like 12inch is the way to go. anyone have any experience with 12" 300W subs, whats a good punchy sub or is that more of a function of the enclosure, i.e. sealed vs open.
I loved my 12" CVR ran off a 350.2. sounded great in a sealed 1.0cf box and got suprisingly loud in a 3cf ported box, people always thought I had 2 15's. CVRs are on ebay for 100ish. just my 2c.
How much do you want to spend?
You might also want to talk a look at these drivers:
Soundsplinter RL-i
Ascendant Audio Assassin
Resonant Engineering SE
Stereo Integrity Magnum (I've heard great things about these, even off very little power)
ymee
ymee
San Diego
SSS 18734
