What will give me more spl??
wlmrs
Realm Of Excursion
I am going to build a ported box for 2 12's with 1400 watts of amplifier power(rms).I'm debating whether I should build it with circle or slot ports??what do you think will give me maximum spl?also if I do slot port it,should the subs have a divider with there own slot port? Or no divider with one slot port off to one side of the box.The reason i ask is because about a month ago I bought a prefab box with one slot port in the center between the subs and it sounded horrible.(no bass whatsoever)Thanks to all replies
The box sucked because it was a prefab. I read that the only reason why there are dividers is just for bracing. When I built my box i did not use a divider. I would build a slot port. Because whats the use of buying extra material, when you could just make a slot port out of wood.
are you sure no divider???i would really hate to build this box and have it sound like crap due to no divider and besides won't the subs be fighting (cancellation)for the same airspace?
trust us some people here make boxes liek its our job.. shit some even do make em cause it IS thier job. its a pain to build two chambers. more wood, more port calculations, more gross box area, etc. the subs wont fight for airspace.
and x100000 on the slot port, make it rounded off on the inside though to help port noise
wlmrs
Realm Of Excursion
wlmrs
Minnesota
wlmrs
