What to Get
woodplock7
Hey guys ive finally decided on the next setup i will be running... its going to consist of 2 ssds and a zx1500.1 ive already ordered the subs and the amp ill be ordering today.
Well my question is what to buy for wire, right now i have some 4ga wiring kit that was hooked up to my 750.1. So should i just buy a kit, if so which one should i get? If not what should i get? Also you guys how do you think my electrical will hold up, right now it consists of the stock 105amp alt, and a yellowtop up front. If i got another yellow top in the back would i be fine for the electrical the zx1500.1 is the only amp im running right now. Thanks so much
well i was looking at kits and i saw this one on ebay.
TSUNAMI AMP01BL 1/0 AWG GAUGE WIRING INSTALL AMP KIT
you think this would be good enough to run my system off of cause if i wanted to upgrade even further later i have the wire already bought. these are the specs
17' 1/0 Gauge Blue Power Cable
3' 1/0 Gauge Silver Ground Cable
17' 18 Gauge Blue Remote Turn-on Wire
1/0 Gauge 1 Position ANL Fuseholder
250 Amp ANL Fuse
(2) 1/0 Gauge to 5/16” Nickel-Plated Ring Terminals
Blue & Silver Insulators
Heavy Duty 1/0 Ga to 5/16” Nickel-Plated Ring Terminal
Clear Insulator
Heavy Duty Nickel-plated Ground Terminal
HARDWARE PACK:
(10) 6” Cable Ties
(6) #8 x 3/4” Phillips Nickel-Plated Panhead Screws
(2) Red Vinyl #10 Nickel-Plated Spade Terminals
(2) Blue Vinyl Butt Connectors
1/0 Gauge Snap Grommet
Yeah, you'll want at least 1/0 from the front to the back.
That wiring kit will do the job, but it doesn't include RCA cables or speaker wire. Do you already have some? You'll also need a distro block that does 1/0 to 4 gauge. And a couple lengths of 4-gauge to go from the distro block to the amps. And a couple more lengths of 4-gauge for grounds. And some ring terminals for the 4-gauge grounds.
They have good deals on all of this at http://www.knukonceptz.com
I misread your post. I thought you were going to have a zx1500.1 and a 750.4, and not just replacing one with the other. In that case, that wiring kit you listed should be fine.
woodplock7
woodplock7
Florida
kross
