What to do here
if this is for daily then a single one would be more than enough.
either the 1800 or a single 1100
the 1800 will give a single 15A 900 watts or a pair of 15A will see 900 each
the 1100 with give single 15A 330 or 1100 depending on how it is wired. or a pair of 15A's with share 650
but for most ppl that is plenty of power for a single sub daily
iirc you put a pair of 1100's to the 15A for daily and you will be digging into your pocket for repairs
Monty
if this is for daily then a single one would be more than enough.either the 1800 or a single 1100
Monty
what does that mean that he will be digging into his pockets for repairs?
well it would be 1 DB 1100 for each sub probably, i was wanting alot of power, and know it would be loud as hell, but would it be much of a difference if 1100 went to each instead of just 900, and will i blow a A with only 1100 watts since they are sposed to be 1500 max
yess u will and if u have 2 DB1100.You will need and electriacal upgrade. U could also go with a US amps. but the tsumani will be fine
sweet, yeah i would def. be getting a bigger alt. for all this, but what amp alt would i need, i hear just take off a 0 and thats what u need, so would a 220 amp alt. be good? Plus would a pair of amp caps help at all???
The 1800 would be WAY more efficient and less of a headache. And I personally dont think that you will be able to hear the difference between 1800 wrms and 2200 wrms, I mean that is only 400 wrms dif and thats not much of a difference when your running that many watts anyway.
flyasspimp
onebadmafugger
flyasspimp
The Ghetto
LBX2G
