What to cut holes with?
I knew a guy named jig, he was really cool. But now he wants to hurt me //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
sadpanda
if you set the speed of dremel too high, you will burn your wood. it also depends on the dremel bit you are using and rpm. dremel is easy to use. i could cut a hole in a minute or two.
There are so many different things you can use. Depending on the jig saw will depend on the quality of the cut. Some jigs have a blade you can pivot 360 degrees while you are cutting. Bottom line is take your time and do not force your cuts. Use a fresh sharp blade and you will be fine. If you have the money a roto saw will also work.
That Guy 1
That Guy 1
somewhere in Uhh...
paikiah
