What terminals for Northstar NSB batteries?
I tried it with washers and 5/16" rings on a power inverter. It must have had a bad connection doing this because the negative post got really hot. I am worried about this happening in my car.
The top of that battery connection should be solid metal that the ring terminal will contact directly. The washer should be between the ring terminal and the bolt head. As long as you have it assmebled that way, you should have no issues. Just make sure all the contacting surfaces are clean before assembly.
groundpound4200
Da fuq did I just read?
groundpound4200
Mankato, MN
Lakota
