2 kicker kx1200.1's strapped, so at least 2400w rms.
working with about 9-10 cubes before port/sub/bracing.
will be walled off in the Mini cooper to the front seats. what should i run? i have a 12" MT, which is about 60 lbs, i was gonna run that, so if i run multiple subs now in the wall setup, thats fine, as long as they dont exceed the weight of the 12" MT (give or take a few lbs)
i will prally use Trupan since ill only need a sheet of it since its a small car, so i dont mind spending a little more than birch, id rather cut down the weight as much as i can. so i mean weight of subs, maybe like 75lbs total max....but what should i run with that power, i want something thatll get LOUD and LOW, but i want it to be good on the higher notes as well, not just hit the lows. i want it to be a good daily loud *** system. tuning im thinkin will be around 35-40, prally 40.
