what port length for 35Hz?
oldschoolboomer
built 23.9 gross square foot "wall" yesterday. the port dimensions are 5.25 x 50.5 x ?????. I need to know how long to make the port for @35Hz tuning. Maximum length is 19.25 which I believe would tune to @29Hz which may be a bit low for se15's. Need help asap as I want to get the port in and start the bracing and finishing work today.
can you widen it a little? or is that not an option. say 7 x 50.5? then it would be around 16 inches and box volume would be around 22 cubes. i'm assuming you made a mistake by saying 23.9 square feet. it's 23.9 cubic feet? correct?
meant cubic feet. The port is only 5.25 tall due to space constraints. The overall dimensions of the box are:24.5" deep x 37" tall x 52" wide. This is for 6 se15's.
well. my calculations are wrong then. what is the displacement for each woofer?
oldschoolboomer
oldschoolboomer
white house, TN
Dutchie.
