What kinda Memphis Sub is this?
If anyone has experience with PRD1000.1 & MCD1000 how would they be rated?
mcd1000 is closer to 1200wrms then it is to 1000. it's got a smaller footprint, more efficient design, and a selectable subsonic filter.
the pr1000d is 1000 and no more. isn't quite as efficient, is larger, and it's subsonic is just on or off. you can't select the frequency.
both are great amps, both will get the job done. but if you have the extra money, the mc is the one to get.
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
Um, no.
The SHP is the SHP and the MOJO is the MOJO. The mojo had a non-cartridge cone when it came out. Then they went to field replaceable ones. also the mojo motor is much bigger.
in technical terms, you are correct. but for simplicity sake, the shp was the memphis superwoofer (not counting the lvs, which is a big POS), until the mojo came out. and the mojo motor isn't all that much bigger.
mojo motor is ~3/8" taller then the shp. they are the same diameter, and have the same size pole vent. IIRC, they have the same VC diameter. so i wouldn't exactly say much bigger, would you?
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
Have you ever seen a bench sheet for them??
nope. but as a previous owner of both and a current dealer, i would believe the specs to be pretty **** close.
mcd1000 is rated 1100x1@1ohm
pr1000 is rated 1000x1 @1ohm
and in my experience with both, the mc was noticeably louder. and most definitely easier on the electrical system
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
So the MC is smaller, more powerful an easier on electric. Had any experience with this years PR? Maybe Im looking at wrong PRD1000.1 but this has Sub sonic, Low pass, Bass eq an Gain all with adjustables.......
not had any experience with the redesigned 07 pr1000ds.
i wouldn't hesitate to run either one.
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
If have any experience with BXi1606D or MM1000.1(Autotek) how those compare??
OoMesKoO
Me > Newbs. :fyi:
OoMesKoO
Rhode Island
questionaire
