What kinda amp would get the most outta these subs..
Sundown 1500d
i couldn't find a sundown 1500d amp anywhere online //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
crunch 3000.1d
someone told me that the rms of the subs has to be equal or less than the amount of power @ 4 ohms on the amp
the rms is 1000w and that amp is 750-Watts x 1-ch @ 4-Ohms
is what i said above true?
plz let me know.. thanks
no, you can underpower or overpower subs and they will work just fine as long as you know what you're doing
i prefer to overpower mine by about 50%
No, not even close. Since each sub is a dual 4 Ohm voice coil, you can wire each to either 8 or 2 Ohms. With two of them wired together, you can choose 1, 4, or 16 Ohms at the amp.
Since they can each handle 1000W RMS, look for an amp you know will do at least 2000W RMS at 1 Ohm.
This might be a good starter amp, but try to scour the FS section for a used Kicker 2500.1 (technically not rated to handle a 1 Ohm load, but it will, iirc) or a RF T1500.
thecoolest
thecoolest
in yo mama
DejaWiz
