What kind of wire do I need here...
  • 2
SpeeDFX
I'm installing JBL 1200.1 and a JBL P80.4 amplifiers, the 1200.1 is going to drive 2 shvas and the p80.4 is going to drive my 4 Kappas in the front and back.
That size of wire should I use as a power wire, and what size of wire should I use after the power wire goes into the d-block and I have to split up the power?
thx
Rings? I've had to make them before because the factory speaker mount was plastic, and I've had to make them so the windows would clear the...
11
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
8
349
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
8
808
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
4
822
SpeeDFX
SpeeDFX
Altadena, CA
Mark_ab
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
