What kind of powered home theater sub should I get?
93 saturn sl2
My 12" Sony powered sub isnt cutting it anymore. I want something that will get louder, and have tons of bass if I crank up the volume. I'll be moving my home theater equipment to my basement, so it has to be able to fill a larger room.
I was checking out the Dayton audio subwoofer kits over at partsexpress., but the one I would want with the Titanic sub is pretty expensive.
My limits about $250-300.
Thanks.
People with that budget would use a Dayton Quattro woofer with the 250w
plate amp, total cost $200 plus the cost of building materials. You can hit
the $300 when all is said and done. But that type of subwoofer is hardly
a subwoofer in performance, but it may work. I don't know if it's going to be
much better than what you have now.
Next up on the food chain migh be a $200 Dayton Titanic woofer with maybe
at least a 500w plate amp. $440 plus building materials.
If I really wanted a good sub for a basement, then I'd look at the $300 woofers
with 1kw plate amp. This puts you in the $650 price range plus building materials
and it would probably last a long time with less upgrade itch.
To name a couple of popular woofers;
http://www.soundsplinter.com/rlp_premium_series_12_and_15_inch_subwoofer.html
Flavor of the month is this one.
http://www.tcsounds.com/tc2000.htm
Ported EBS style design for HT would be sweet. It would be a big box but
it would destroy store bought product costing alot more.
I must say that those subs are a bit old news around this car audio forum. But, both have decent success as home audio subwoofers.
However, you might be better off looking into a Fi Q or something like that. Cheaper than the TC but more powerful than the SoundSplinter. I have a Q 15 in my car and have been thinking about getting a 12" to experiment with in my home system.
However, those speakers alone are the price of your whole system that you want to put together, so lets not get too ahead of ourselves here.
I defiantly wouldn't expect too much out of that price range that you have there, especially prefab. If you can build the box yourself you would be much better off. I would not go smaller than a 12" if that is what you have currently. An, SSD 12" is $189 which gives you some amp options.
With that speaker I would go with one these two:
BASH 300 Watt
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=300-750
BASH 500 Watt
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=300-752
Personally the extra wattage can not hurt if you setup your system right. Also, were you thinking ported or sealed?
I assume you can build a box yourself?
Every subwoofer is old news on car audio forums, lol...
Old news doesn't mean bad news... It won't take too much to beat a Sony
powered subwoofer, but why beat it when you can destroy it with a bigger
budget. Makes no sense to spend $300 on an HT sub only to see it go obsolete
after a short time. Save up and make a big EBS sonosub and it will last for years,
but can you transport the beast downstairs, maybe something this size?
http://dustin.bunnyhug.net/pics/driverampangle.jpg
When choosing your amp, you need to choose wisely and match woofer impedance
to amplifier's lowest impedance if you want best performance. If you buy DVC woofers,
pay attention to coil impedance {series or parallel wiring} and then determine which amp is better suited.
The plate amps are typically 4 ohm optimal, proamps are 2 ohm/ch or 4 ohm bridged optimal,
and the Buttkicker amp is 2kw @ 2 ohm mono. This is a nice amp for about $250. Also
check how you will crossover the sub.. external crossover or crossover that may come internal
with certain amps.
http://www.audio-discounters.com/bka1000-4a.html
A few years ago these were highly rated, and there seems to be a few new ones still available-
YAMAHA YSTSW315
10" cone driver
250W Amplifier
20 to 160 Hz frequency range
Advanced Active Servo Technology
BASS Selector
Yamaha's QD-Bass Technology
Magnetic Shielding
Continuously variable high-cut filter from 40 to 140 Hz.
Volume Control
Signal Sensing ON/OFF:
Phase Normal/Reverse Switch
Dual Inputs
Three-way speaker terminals
Black Ash finish
Dimensions (W x H x D)
13 3/4" X 17" X 15 1/16"
Buy It Now price: US $166.66
http://cgi.ebay.com/YAMAHA-YST-SW315-HOME-AUDIO-STEREO-SUBWOOFER-SUB-WOOFER_W0QQitemZ180077900887QQihZ008QQcategoryZ3275QQtcZphotoQQcmdZViewItem
Every subwoofer is old news on car audio forums, lol... Old news doesn't mean bad news... It won't take too much to beat a Sony
after a short time.
Subwoofers have a very short "flashy" time on a forum like this where Hype rules a lot of posts.
ALSO, if he doesn't have that budget it makes sense.
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
And, you are very right about matching the impedances. You can't run a plate amp a .5 ohm, usually.
It sure would, but it was really well reviewed by the home theater mags about 4 years ago where they liked it as much as most $1,000 subs.
(I think it originally sold for about $600 back then.)
Hmmm Interesting looking guy there.....
/begin joke
I don't think anyone has a *real* budget for any hobby. Here's how an audio
hobby works.
Time index 1; You spend $200 on a speaker project because you have no more money.
Time index 36; You are bored with your $200 speaker and need a new and better one. You spend $300 on the next project.
Time index 66; After careful review, you need to go to the next level because
it's not quite right yet. You spend $700 on the final project.
Total cost: $1200
$1200 is alot of money for someone to spend considering they don't
have more than $200 to spend. lol ....
/end joke
Yea.... I started out with my dad's old speakers....
Then got a new Receiver.
Then a power conditioner.
Then a new DVD Player.
Then surround speakers.
Then new Main channel speakers.
Then another new DVD Player.
Then a amp.
Then a processor.
Than a CD Player.
Then a new TV....
I don't want to know what's next.... But it will be expensive.... :|
If you heard it
... and liked it ...
case closed //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
93 saturn sl2
93 saturn sl2
Michigan
thylantyr
