ok thank you, me and xjbuminbeast are friends, hes getting an L7 and I got and L5. but we are both getting the same TMA 1000 watt amp. and both have a sony hu.Not amps. Watts.. and I would use 700+ on that woofer... Also, your box looks WAY to small and is sealed. Everyone keeps telling you to do a 3 cubic foot ported box.
thats fine i want loud! How do you tune a box btwIts a different guy that jumped in with those pics
And yes that box is way to small if youre trying to get "loud", ported is what you want, but be prepared to give up atleast 3X more cargo space than that current cube takes up
thanks again but if i run it using two ohms ill get 700 to the L5 correct? And is there a massive difference between the twoBy calculating. Not just a simple whole in a box.
Check this link.
http://www.reaudio.com/speaker_box/LPort_Box_Calc.html
You enter in your own measurements, and make it EXACTLY as it says, gives you cut sheets and everything. Tune for 32-34hz and try and get atleast 2-2.5 cubes for your L5
Be very careful powerring that L5 with 1000rms, it wont take it like the L7 will
thanks for the help, im def gonna do research before i buy a ampi dont think those tma amps are any good, i might be wrong tho.
go with a hifonics, they are cheap and do about rated power.
U can find a 1000wrms hifonics for around 150 or cheaper.
I would but i dont want to over power it and wot im pretty sure it is and thank you for all your informationThat TMA amp is fine, my friend uses one and it does rated power and runs cool. It is an excellent deal for $200. If you were looking to run an amp @2ohms, I would look at the Kicker ZX 750.1, they do closer to 900 watts @2ohms.
