What kind of amp do I need 15 inch Sub
Ok cool i did 3000w /16v max output and calculated 187.5amp just wanted to make sure as i said all new but its not so complex.
Just gotta work out battery side now, hopefully not to much price and complexity involved aha but should be good now appreciated.
Do some research on Big 3 electrical upgrade. You'll need some heavy wire for power and ground for the amp as well.
Thanks yes it also suggested on YouTube recommendations so awesome. Will revisit and check through.
Rings? I've had to make them before because the factory speaker mount was plastic, and I've had to make them so the windows would clear the...
A 5 channel amp is fine. The front and rear speakers are the the same efficiency so at any given input, they will be the same volume, relatively...
Thanks for all the advice. Ultimately, I was able to get them to honor the warranty contract. It took a lot of back and forth and I received...
225
Never said they were. Commentary was more to being able to purchase one or the other or 40% off and take a 90 day warranty... which I would in a...
266
Lowering the impedance will also lower the speakers motor control, or damping, in physics no free lunch exists. It’s all give and take.
203
Carice222
Carice222
UK
Jeffdachef
just call me KeV
    Apr 27, 2024
just call me KeV
    Apr 27, 2024
