ridered36
Dont bufu rabid squirrels
I need to know the area the driver takes up inside the box. Here are the specs:
12XXXQ1.2
Re 1.17 ohms per coil
Fs 34.4 Hz
Qms 5.19
Qes .49
Qts .45
Vas 31.6l
Sd 480cm^2
Xmax 32mm one way
1600 Watts RMS
SQ: .75-1.25 cuft sealed or 2.5 cuft tuned to 23Hz
SQL: 2.25 cuft tuend to 33 Hz
SPL: 2+ cuft tuned to res freq
Also, it says 1.25 for sealed. Is this w/o driver displacement, or does it need to be 1.25 with driver displacement?
12XXXQ1.2
Fs 34.4 Hz
Qms 5.19
Qes .49
Qts .45
Vas 31.6l
Sd 480cm^2
Xmax 32mm one way
1600 Watts RMS
