What is the deterministic quality of an SQ sub?
Zylo
What really makes for an SQ sub?
Is it the ability to respond to different notes quickly and without "lag", or more the ability to reproduce a certain type of sound? //content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
I just purchased an ED 12O for my brother along with a 400W avionixx amp. It is in a 1.5cf sealed box built like a tank. It sounds GREAT.. however in my ears, it lacks warmth. It has mucho punch, and really sounds like a kickdrum in the trunk! It could keep up with anything we threw at it! Currently have the cutoff @ 80hz.. before, when I had 3 10" xplods, anything over 50hz was just UNBEARABLE! //content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif
However, I felt it lacked the ability to reproduce rap/techno to my tastes.. it just lacked warmth, and fullness (smoothness)
It was, however, MORE than loud enough for me..
If only I could throw a Velodyne HGS-18 (now called the DD-18) in the truck... listening to that sub @ one of my buddies house was just.. ****ing... well.. better than ***! :thumbs_up
It posses all that I want in a car sub //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
So, what makes a sub have a fuller, richer sound while still being able to keep up with fast paced music? (the HGS-18 is the perfect example of this)
What gives a sub the ability to play real-real-real low?
I stress this, becuase the HGS-18 would play so low, you could feel it, and the only sound was shit around rattling.. oh it was sooo badass!! Why did Dave have to ****ing move to Arizona!! //content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif THAT was verycool, IMO!
And, how can I achieve the sound I want, without massive SPL levels?? This is in a 100% daily-driver app.. no competition (SQ/SPL) whatsoever..
As far as what music I will be listening to.. (if this helps) Mostly rap and techno and a mixture of rock (heavy, industrial, soft, oldies) and some country. I drive a truck.. how could I NOT listen to country music? //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
Thank you.
Zylo.. back to the n00b, Part I!
If you think the O is a little too 'attacking' for you, try the A in a slightly larger than recommended box... You'll get a more mild attack (plenty forceful, but again - not harsh-like), and a generally an overall smoother sound.
You can EQ either to sound like the other, but that takes time and a robust EQ.
YOU'RE robust.
Ok take a Sony Explode Sub setup....dual 10"s running 500W RMS. It will sound like *** no matter what you do. Take a Concept or MBQuart sub setup...dual 10"s running 500W RMS will sound supreme. Just because the voicecoil can process more beats and the general construction of the woofer cone, surround and voicecoil are all factors. And the material that the Magnet is comprised. It can produce a crisp, tight bass or it can produce a smooth rounded bass or it can be all around crap.
Well, what most people describe as "warmth" is typically distortion in certain harmonics (Not sure which ones, I think it's 2nd and 3rd). As far as depth goes, add some polyfill (1-2 lbs.) or build a larger enclosure and that should help out ...
1-2lbs for what volume?
Well,
auditioned some JL subs today.. never heard a JL sub before.. I must say, they sounded good! Listend to a 15W3 and a 12W3 V2.. they seriously lacked the PUNCH! of the K, but it isn't quite what I want //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif so that didn't matter to me. The response of the woofer seemed pretty good, with no harshness between notes (something the K seems to have)
The 15W3 did not impress me. The output was ever-so-slightly louder, yet didn't have much of a different sound... not boomy at all (which is what I figured it would sound like compared to a 12"). This could be due to the wrong size box, or many other variables, but the 15" did not impress me at all..
With two subs playing vs. a single sub (two 12W3 V2's), it seemed to have more of that "fullness" I was speaking of.. and a heavier bottom end. So maybe 2 12's are more of what I should look for...
All of the listening I did was on a 300/2 JL amplifier.
I wish someone 'round here had a Magnum D2, Brahma, and XXX I could listen too //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Well,
W3's are lightyearrs away from D2, brahma, and XXX performance
Well,
Where in holy fu*k is Nerk? If it's anywhere near Cleveland, you can come up in about a week or two to hear a 15" XXX. And ngsm13 lives in Cincy, he's got some D2's.
20 mi east of columbus just off I-70.. its also about 20mi west of Zanesville.
Thanks, Captain Obvious //content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
j/k
I know Brahma's will completely ***-**** w3's... even w7's.
Ah, well if you ever find your way up here, you're more than welcome to hear my setup.
Pioneer Premier 850
CDT CL-61's in custom kick panels
Peerless CSX 6.5 midbass drivers for rear fill
Cadence Z4000
2003 15" XXX, ported box, tuned to 30
Hifonics BX1500D
yeah, well is that newark ohio? or is it anywhere near buckeye lake? j/w...b/c if u are ever near cincinnati (like gauntlet mentioned) i'd be more than happy to show you my setup! check it:
Alpine 7894
CDT classics 6.5" components cl-61a
US acoustics usx 2080
2 stereo integrity magnum d2's
2 avionixx 1200.2's
HO 200 amp alternator
Red top under the hood, yellow top in the rear
0/1 awg wiring throughout
new custom designed special box! :thumbs_up
Alpine 7894
2 avionixx 1200.2's
If I stand on the roof of my house, I can see Buckeye Lake. All that seperates me from the lake is 1/6 mile of woods and Papa Boo's!
Zylo
Zylo
Nerk, Ohio
ngsm13
