What is the Best Brand of subwoofers
Pretty much anything I listed above will have good SPL and sound quality. Allthough I think ED is geared more toward Sound Quality than SPL but they will still get fairly loud in a ported box while still retaining sound quality.
Anyone else wanna help out? Perhaps give him some final options on what he needs.
Actually I believe all those subs forementioned are "SQ" woofers except for the Death Penatlty, which I do believe was geared for SPL(and is **** good at it!).
I would recommend a 12XXX or a Magnum D2.
The d2 if you have tight space and the XXX if you have all the space your little heart desires.
werd, XXX's wang.
id grab a set of D2's in a sealed box or a XXX ported.
acually ive been looking at the spl subwoofers at http://justwoofers.com/Woofer_Pages/SPL/SPL_SPL.htm
the SPLW-15
• 2800 watts power handling
• 340 oz. magnet
• 4” BASV/Kapton hybrid 18 AWG voice coil
• Dual 1 ohm voice coil
• Die cast aluminum basket
• Black wrinkle finish with Diamond cut
• Cloth laminated paper cone with MD6 coating
• Black wrinkle finish front & back plate
• Large foam rubber surround
• One piece, 360º rubber gasket
• Dual Conex spider
• Woven tinsel lead through spider
• Chrome screw terminals
• Includes deluxe wood case
• SPL 92 dB
• Sealed box: N/A
• Ported box: 3.4 cu. ft.
• Tuning: 40 Hz
sounds like a good deal: get 2 for $358 but idk i want quality not cheap shitty sounding ****ed up subs
there is no one best sub company
there are well build and well preformers and ones that are a combination of both, but you need to listen for your self to see what your ears like the best
DJ_Hoerst
DJ_Hoerst
Florida
denim
