What is more important. A battery or an alternator?
well?
  • Total voters
    31
They kinda go hand in hand, to be honest.
You want a nice battery than can hold a good charge and voltage for you, but on the other hand if your alternator wont supply the current to keep that good battery charged, it doesnt do you much of a **** good.
I upgrade whichever I feel is lacking the most. If the stock batter has 1000CCA, works fine, and no other issues and you have a 75A alt, then I think upgrading the alt should come before upgrading the battery.
Well I guess to an extent that logic is good. Stock lead acids though even with cca of 1000 aren't as good in other specs as other technologies though. However under the scenario you mentioned it seems to be more understandable that the alt should be first.
I still say to rob someone so you can do both though //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Well I guess to an extent that logic is good. Stock lead acids though even with cca of 1000 aren't as good in other specs as other technologies.
Which is going to create the biggest difference, An upgrade to a 200A or swapping to an Optima Yellowtop? Which change provides the greatest impact?
well if you plan on adding more power in the future, you might as well knock out the most expensive peice right now, beeing the alt. Then just add batteries from their.
But if your broke, buy a batt
Getting off topic, when I installed my 200AMP DB electrical I started getting 1MPG less. So I have daily costs on top of the initial purchase too //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif **** weak *** 4 cylinder shitbox.
Being that the alternator is the heart of your electrical system it is by far the most important. You will see a lot better results from upgrading your alternator over adding another battery. However, if your battery is already in poor shape then you have other issues to take care of than upgrading the alt.
IamDeMan
Banned
IamDeMan
/dev/null
ngsm13
